584,865 active members*
4,876 visitors online*
Results 1 to 3 of 3
    Nov 2018
    CTEK Mill- X/Z Over Lag error
    Ctek CNC Mill - KM100D
    Machine suddenly stops while program is running and when machine is idle in manual mode. The alarm on screen shows an "x-axis overlag error".
    When this occurs the machine moves fast a small distance in the x and z direction (out of tool path) which damages the tool and machining stock.
    I have tried :
    - Cleaning axis guides and lubricating.
    - Running different programs.
    Any help would be appreciated.
    Dec 2003
    24
    Re: CTEK Mill- X/Z Over Lag error
    Quote Originally Posted by SrivanG View Post
    I have tried :
    More likely encoder/cabling/motor/drive issue. Have seen ctek with bad encoder (cold solders) and unbonded magnets in motors.
    Reg. Mika
    Lähetetty minun B15 laitteesta Tapatalkilla
    Apr 2020
    Hi there i have EXACTLY the same problem (although it's the X/Y axis and i have had the sudden movement tto which damages tools and the job.
    Did you ever find out what was wrong as i have no engineers in my area that can help.
    Many thanks
    Pete
  1. Predator Error (\MILL\FANUC0.RPM.)
    By Machineit in forum BobCad-Cam
    Last Post: 04-18-2015, 05:19 PM
  2. V25 error on mill simulation
    By Higgs in forum BobCad-Cam
    Last Post: 05-07-2013, 06:23 AM
  3. EMCO WinNC error 8 (PC MILL 55)
    By AWysiecki in forum EMCO CNC Machines
    Last Post: 09-08-2011, 05:58 PM
  4. Excel 510 cnc mill servo error
    By meputtin in forum MetalWork Discussion
    Last Post: 10-01-2010, 03:03 PM
  5. Error in mach3 mill
    By EL34 in forum Mach Mill
    Last Post: 02-22-2008, 05:45 PM
