585,749 active members*
3,844 visitors online*
    Mar 2014
    33
    2hp J Series Head Bearings
    Does anyone know the actual Bearing numbers for a J series Head? Looking for the top cap bearing, and the bearing under the adjuster plate for the variable speed.
    I don't need the spindle bearings. Thanks
    Jun 2017
    32
    Re: 2hp J Series Head Bearings
    Good diagram here:
    https://www.machinerypartsdepot.com/...57/page/547181
    Very friendy, helpful folks too. They know Bridgeports and get parts out ASAP.
    In lieu of that, measuring the ID (1.375 IIRC) / OD (2.375iirc) , how thick, thrust, etc and contacting a local bearing supply house can get you fixed up too. Pretty sure they're all spec'd abec-7 / sealed.
    15362
    Quote Originally Posted by SchortBus View Post
    Good diagram here:
    They are only regular deep groove Bearings 2RS is all that is needed, the spindle is the only part that has ABEC 7 Bearings
    Mactec54
  1. Series 1 Boss 3 Head Rebuild (2J Head) - Stuck Here.
    By 1875 in forum Bridgeport / Hardinge Mills
    Last Post: 03-20-2022, 07:59 PM
  2. 5 axis head bearings
    By CNCImpulse in forum Other Machine Topics
    Last Post: 07-30-2017, 09:03 AM
  3. Grizzly (G8688) 7x12 Head Stock Taper Bearings
    By Danny X in forum Mini Lathe
    Last Post: 05-27-2011, 10:05 AM
  4. Obsolete Norma bearings...J head
    By tom in nh in forum Bridgeport / Hardinge Mills
    Last Post: 03-10-2009, 12:57 AM
  5. J-Type head spindle bearings?
    By GalaticDan in forum Bridgeport / Hardinge Mills
    Last Post: 01-15-2006, 03:36 PM
