Re: Saturn 2 4x4 w/ Nema34 closed-loop - In Canada
Does the machine cut and rout accurate work? If your chasing .001 just for the thrill of the chase or are you putting out boards that are not routed or cut to reasonable standards for woodworking? Are you tossing a lot of wood into the burn pile? If the machine is not capable of doing the work you require then send it back.. My machine is more capable than me.
Some people have sent back, got a refund and are still not happy. Some have sent back entire gantries and had it replaced and still not happy. If you think the spec's are not correct and it makes crappy doors or widgets for you, sent it back.
Bottom lIne. If your not happy take Nate at his word.... and send it back and buy a machine elsewhere or do what GME is doing build the prefect machine.
