Hi! I have a big problem. I bought a Hurco vmx 40. If fast feedrate incrementally decreases the distance, if the slow feedrate incrementally increases the distance. Each axis makes the same mistake. For example, if you move 800mm, then 800.01mm is actually. If I do the same thing several times, 0.01mm is added. If 800mm goes to the machine for 5 displacements then it is 800.05mm. What could be the problem?
