585,917 active members*
3,445 visitors online*
Page 1 of 3 123
Results 1 to 20 of 57
    May 2013
    19
    Exclamation Spindle Voltage Output
    Hey guys.
    I could really us some help finishing up connecting my 2.2KW spindle to my CRP Plug and Play electronic box. I have followed the instructions of the youtube video below. I have the exact setup from the spindle, inverter, Mach3 and breakout boards. I have checked all the parameters and found out that the breakout board is only supplying 7 volts to the inverter. I have changed the spindle speed from 24,000 RPM to 12,000 RPM and it still outputs 7 volts. The spindle turns on by Mach 3, but I cannot change the speed in Mach 3. Any help would be greatly appreciated.
    https://www.youtube.com/watch?v=jVirHq2kHKU&t=651s
    Mike M
    Re: Spindle Voltage Output
    So, that's not your video??
    Need to see your Mach3 settings.
    May 2013
    19
    That is correct this is not my video. But I have the same settings that he is showing. I apologize if I was not suppose to link this video. What other settings in mach would you need to know.
    Mike M
    Sent from my SM-N950U using Tapatalk
    ports and pins > Output pins.
    May 2013
    19
    Here is what I have for the output
    Attachment 405962
    Sorry, I meant motor outputs, specifically for the spindle. I was going by memory, as I don't have Mach3 installed here.
    May 2013
    19
    No Problem. Here is the motor output
Name:	Motor Output.JPG
    ericks Guest
    Quote Originally Posted by millerm499 View Post
    This is mine and it works fine
    May 2013
    19
    I made the changes to Mach3 and it seems that the output voltage is different. When I tell it to output 24,000 RPM it outputs 5 volts. When I tell it to output 12,000 RPM it outputs 3 volts. But the RPM do not change.
    ericks Guest
    Now you getting a varying output which is a good start
    May 2013
    19
    Yes. I agree, but why would it be 5 and 3 volts instead of 10 and 5 volts for the above RPM.
    ericks Guest
    Do you want 0-5V or 0-10V from you bob to your VFD...don't worry about the rpm not changing yet...we can sort that just now
    ericks Guest
    Okay you just answered my question....you want 0-10V. Now i am not sure what bob you using, do you maybe have a selection on your bob for 0-5V / 0-10V??
    May 2013
    19
    Quote Originally Posted by ericks View Post
    I am pretty sure that it is a 0-10 volts because it was producing 7 volts.
    ericks Guest
    True that makes sense....i need to know your other settings for the spindle
    ericks Guest
    I used a relatively low pwm base frequency because i use a microcontroller to read this signal. You might use a higher frequency
    ........select minimum pwm as 0
    basically use my settings as a starting point
    What are your pulley speeds set to?
    May 2013
    19
    Max 24000, min 0, ratio 1
    And if the voltage is changing, but the VFD is not, then you're VFD settings are wrong. Check PD001 and PD002. There's also a jumper that needs to be set correctly.
    May 2013
    19
    I have checked the PD settings. Where is this jumper located. Do you have a pic that might help.
Page 1 of 3 123
  1. Output voltage from Output Board seems to be quite low?
    By cdfleischmann in forum PlanetCNC
    Last Post: 07-25-2018, 12:18 PM
  2. Replies: 0
    Last Post: 03-20-2017, 12:35 AM
  3. Output 2 voltage
    By Claytonc in forum DIY CNC Router Table Machines
    Last Post: 03-18-2012, 11:48 PM
  4. G540 Spindle speed output voltage problem
    By georgef8 in forum Gecko Drives
    Last Post: 09-22-2009, 04:18 PM
