I recently bought my first cnc machine. It is one of those really small table top models from China cutting area is 130mmx90mmx40mm the spindle that comes with it is rated at 30 watts. I really would like to replace this with an rc brushless motor so I have the ability to cut acrylic that is the whole reason I got it to cut acrylic pieces. I read that to cut acrylic you normally want a motor that can spin up to 18k and to use O-Flute end mill. Since I plan to use just 3.175mm size end mill. What type of power figures should I be looking for in the motor watt wise? Also max diameter for the motor I can use on it is 36mm for inrunner and 35mm for outrunner.
