586,013 active members*
4,221 visitors online*
    Jan 2006
    204
    old C11G hookup question (rev 5.4)
    I have a older C11G rev5.4 breakout board it has a en (enable) pin and a connection right beside it labeled +5 volts I am wondering how to hook it up there is no 5 volts on the 5 volt connector. I am wondering if that is used to "latch) the board on as wwith a jumper between the two and when 5 volts is applied to the jumper it will start the board to oerate and when the jumper connection is broken the board stopps working (as using it for start and estop buttons
    Happy Hunting
    archie
    Mar 2004
    1806
    Re: old C11G hookup question (rev 5.4)
    You have it correct, you must jumper between the +5 and the en. The original wiring diagram suggests using an E-stop switch between the two. I am attempting to attach a wiring diagram that I have had for many years.
    HTH
    Attached Files Attached Files
    Art
    AKA Country Bubba (Older Than Dirt)
    Jan 2006
    204
    Quote Originally Posted by Bubba View Post
    HTH
    Bubba, Thank you ,
    Arturo sent me this one already. I have +5 volts connected to the board but it will not wake up for some reason.
    could it be a jumper setting
    archie
    Mar 2007
    2083
    to work the C11G needs two enables
    the first enable ( in red ) is the link connecting the +5V terminal to the adjacent enable terminal
    (the enable screw terminal is connected to pin 1 of IC6 on the board)
    the second depends on the charge pump enable / disable jumper (marked in yellow) being in the correct position
    (disable unles the control software is sending the correct pulses to printerport pin 17)
    IC 6 (74LS00) combines the two enables to produce the enable signal for the three 74ACT245 octal buffers that pass the 12 printerport outputs to the output terminals and control the output LED indicators
    what position is the charge pump enable / disable jumper in ?
    is your control software sending the correct pulses to printerport pin 17 to enable the C11G board ??
    as a test , try the jumper set to disable
    John
    Jan 2006
    204
    John,
    Thank You
    The boards woke up by changing the power wires. Now to get them working with the software.
    archie
  1. C11G axis
    By johnd in forum CNC4PC
    Last Post: 08-27-2018, 05:39 PM
  2. CNC-6040 and NowForever VFD Hookup Question
    By JNasiatka in forum Chinese Machines
    Last Post: 05-29-2018, 12:48 AM
  3. Replies: 0
    Last Post: 06-06-2015, 12:56 AM
  4. NM-145 and C11G BOB Questions
    By Krenovian in forum Novakon
    Last Post: 11-08-2013, 03:16 AM
  5. Relé interfase C11G
    By fenixes in forum Spanish
    Last Post: 05-16-2008, 06:29 AM
