585,981 active members*
4,251 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > Cincinnati Sabre 1000 HH 415 ERROR when start pump
    Jun 2015
    46
    Hello guys,
    I have a problem with my machine. When program (spindle, axis and water pump) started or turn off, machine sometimes showing a Gross positioning error... Sometimes when spindle rotate and I hand turn on pump is the same problem. I know what mean Gross positionig error, but now it is not relate with loose in machine. It look like the voltage dropped... I change contactor from pump and nothing better. I do not know where I should looking problem.
    Dec 2006
    584
    Re: Cincinnati Sabre 1000 HH 415 ERROR when start pump
    WHAT IS YOUR INCOMING VOLTAGE, Are you running this machine on a phase converter or industrial 3 phase? It sounds like it is related to a voltage drop. What control and drives do you have on this machine?
    MIKE CNC Machine Services INC | Cincinnati Milacron MachinesCNC Machine Services
    Jun 2015
    46
    It is HH 415 BR. Drives FANUC. Sometimes, but very rarely on PCB show LV LED. Machine is connect to 3phase. I have 3 other machine which working fine.
  1. Cincinnati sabre 1000 Fanuc control parameters
    By Stealth XY in forum Cincinnati CNC
    Last Post: 11-01-2019, 01:59 AM
  2. Solidcam / solidworks on a Cincinnati sabre 1000
    By Stealth XY in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 07-27-2011, 07:57 AM
  3. Cincinnati Sabre 1000 - seeking information
    By nlh in forum Uncategorised MetalWorking Machines
    Last Post: 02-24-2008, 03:35 PM
  4. Help on Cincinnati Sabre 1000
    By alexanderrt in forum Hard / High Speed Machining
    Last Post: 03-01-2006, 05:30 PM
