Dear all.
Most of the work is fine, but when you process the patterned pattern, the part that is pushed in the y-axis occurs
Also, drawings created with integers are not problematic, and only drawings created with a decimal point cause problems
ex) 2mm circle pitch 4mm x 4mm 40x40 array (ok)
1.85mm circle pitch 2.9mm x 2.9mm 40x40 array(fail)
If you have any problems with me, please reply.
thanks regard~
