585,599 active members*
3,477 visitors online*
    Jul 2014
    15
    3D Constant Stepover.
    Greetings from India.
    Can we reverse the toolpath by using HSM (3D Constant Stepover) toolpath?
    We have for our cavity created two tool path, one roughing (HSR) and one finishing (HSM). The 3D constant stepover toolpath is starting from Inside the cavity depth and emerging to the top.
    Please help.
    Regards.
    Jan 2012
    36
    Re: 3D Constant Stepover.
    Hello Junior1505,
    You need to have "Advanced" select to see all the machining tabs available, then you need to go into LINKS and select "From First Pass" under the "Order Passes" header.
    Attachment 406766
    Regards,
    Darrin - SolidCAM
    Jul 2014
    15
    Dear Darrin,
    Am grateful to you for the suggestion.
    Applied the same and worked like magic.
    Thanks a million.
    Regards.
  1. Explain STEPOVER
    By nivlek in forum BobCad-Cam
    Last Post: 11-27-2014, 12:15 AM
  2. Constant stepover on surface?
    By Forrest C in forum BobCad-Cam
    Last Post: 09-03-2014, 02:23 PM
  3. 3D stepover machining
    By the-niho in forum CamWorks
    Last Post: 01-14-2011, 11:24 PM
  4. Tool Stepover help
    By moto21 in forum Mastercam
    Last Post: 08-23-2005, 02:03 AM
  5. Stepover
    By Hack in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 06-10-2005, 06:07 AM
