585,589 active members*
3,549 visitors online*
    Nov 2018
    Cutting Ti on lathe
    I am new here. I was in aviation with USCG for my career and no2 retired after 34 years. My questions are probably basic for most here but I can't learn if I don't ask. I am working on a prototype and one part I must drill perfect center hole in titanium. I am using a lathe to do the drilling. Stock is titanium 1.375 OD held in chuck and 0.050 thickness of material to drill a very clean hole either 7.25mm did or 10.5mm. What bit or bits should I use? I'm guessing something like a carb 135°split bit possible finished with a ream bit, but I am guessing with my basic are space material knowledge base. More lack of knowledge base. Speed and coolant hints appreciated. Thank you in advance.
    J.R.
    Jan 2019
    74
    Oct 2020
    12
    Re: Cutting Ti on lathe
    I think, yes, there is a lot of information here about your problem. Indeed, I saw several familiar to your question topics and specialists that are ready to do it for you. Maybe if you provide https://somamedicare.com/ a little more details here, I will have enough knowledge to do it for you. But what is about the experience?
    Oct 2020
    12
    I have set up and error questions, and I would bet will need parameters. https://calendardream.com/
