585,956 active members*
4,411 visitors online*
Results 1 to 5 of 5
    Jun 2013
    43
    Lubrication type
    Just picked up a Chinese 4x8 machine with 2 manual lubrication pumps. What type of lubrication should I use. I was told sewing machine oil is what they put in it but wasn't sure if it is the best choice. I wanted to see what others are using.
    Jan 2007
    626
    Re: Lubrication type
    I use sewing machine oil on my 6040. I tried spray on dry lube and didn't like it.
    Jul 2016
    660
    Cooking oil here no issues for 3 years straight
    Jun 2013
    43
    Anyone use some type of way oil? I guess I will stick to the sewing machine oil unless I hear of a reason not to.
    Jan 2018
    10
    some people use the same lubrication from car
    ???? BKL-AL20 ?? Tapatalk??
  1. Panel type Furniture Solution High worthy type
    By allencncrouter in forum Videos
    Last Post: 07-26-2018, 02:00 AM
  2. Panel type Furniture Solution High worthy type Cnc Router
    By allencncrouter in forum Omni CNC
    Last Post: 07-25-2018, 02:16 AM
  3. Panel type Furniture Solution High worthy type
    Last Post: 07-25-2018, 02:11 AM
  4. Lead Screw type and bering type????
    By cjluke in forum DIY CNC Router Table Machines
    Last Post: 07-20-2011, 04:42 PM
  5. What type of way lubrication do you use on your Taig?
    By protrackcorp in forum Taig Mills / Lathes
    Last Post: 09-22-2010, 05:11 AM
