I have procured rather cheaply a lathe spindle from a 14" 1960's U.S. made lathe. This is a rather stout piece about 24" long with 2 pairs of bearings 130mm and 110mm sealed ball bearings respectively. The fwd bearings are ND3215 separated by a spacer and the aft bearings are 212KD.
My intent is to modify the spindle and for use in a shop made aluminum headstock as a 4th axis on a CNC mill and as a light duty CNC lathe (lathe tooling on the mill spindle or column with a custom tool holder). This will be driven by a shop made timing pulley by a surplus 1.8kw servo.
I am hoping to get some advice on where to cut the spindle. From a practical standpoint the ideal case would be to cut the spindle behind the fwd bearings, the drive pulley for the axis would then be attached there. This would allow the overall setup to be short and light enough to be easy to handle but I guess the real question is would the spindle still be stable without the rear bearings (I think the rear bearings are primarily thrust bearings)?
I am an electrical engineer by trade and I don't really have the intuition behind spindle design.
