586,011 active members*
3,905 visitors online*
    Mar 2016
    30
    Uc400 questions
    Hi, can anyone please answer the following. Does the uc400 board need a normal breakout board as well. If so is it just a matter of connecting a ribbon cable to the printer port inlet on the breakout board. The uc400 manual is useless and gives no useful information. Thanks
    Re: Uc400 questions
    Technically, no. But realistically, yes. You could plug a parallel cable into the UC400ETH, and wire it directly to your devices, but a breakout board makes things much easier.
    The UC400ETH has two ports, so you'll need two breakout boards to use all of it's I/O, or a suitable dual port breakout board.
    Jun 2015
    943
    Re: Uc400 questions
    Quote Originally Posted by terry1956 View Post
    The UC400 manual is very clear that the UC400 gives 2 ports with printer port pinout. You should treat the UC400 ports just like if they were printer ports of a computer.
    Mar 2016
    30
    Re: Uc400 questions
    Thanks jerry
  1. Well. 2x uc400 runaway events
    By Jon.N.CNC in forum UCCNC Control Software
    Last Post: 08-22-2016, 04:36 AM
  2. odd uc400 probe problem
    Last Post: 06-10-2016, 07:48 PM
  3. 2 machines running from one uc400
    Last Post: 06-03-2016, 02:53 PM
  4. CNC mill questions - thrust bearings, leadscrew mounting, general questions
    By tonofsteel in forum DIY CNC Router Table Machines
    Last Post: 02-03-2012, 10:42 PM
  5. Brass vs Aluminium Vs Steel, questions, questions and questions...
    By alexccmeister in forum Uncategorised MetalWorking Machines
    Last Post: 08-15-2011, 06:40 PM
