585,575 active members*
3,720 visitors online*
Results 1 to 6 of 6
    Dec 2017
    47
    Y AXIS RESOLUTION?
    For some reason I can't get my y axis resolution set to correspond with grbl steps. Using 8030 stepper drivers and nema 34 motors, motor manual says to use at
    1/8 steps, but when I jog at 100 steps or 100mm I get 80mm travel, at 1/4 steps I get 40mm travel, and at 1/2 steps I get 160 mm travel. These are the only options that get anywhere close to the right distance resolution. Have tried every listed resolution and none give me the right distance travel. Is there a gcode command to set the proper resolution? Thanx
    Apr 2014
    215
    Quote Originally Posted by bjwx2 View Post
    Your machine / grbl is setup with the wrong resolution, change the setting in grbl
    Dec 2017
    47
    Re: Y AXIS RESOLUTION?
    Thanx! Using grbl 3.6.1, don't see where to do that?
    Apr 2014
    215
    Mar 2015
    409
    Step resolution is set using settings $100.. $102
    Checkout the GRBL site https://github.com/gnea/grbl/wiki/Gr...-Configuration
    Dec 2017
    47
    Thanx to all! Your help let me resolve this problem!
  1. when x and y axis of cnc machine runs with different resolution
    By pdsherathia in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-09-2016, 06:11 AM
  2. how much resolution do I need?
    By jrz126 in forum CNC Machine Related Electronics
    Last Post: 01-13-2011, 01:51 AM
  3. CNC resolution
    By sinha_nsit in forum Mechanical Calculations/Engineering Design
    Last Post: 10-22-2008, 10:11 AM
  4. Question about Microstepping and axis resolution
    By Tom Kay in forum DIY CNC Router Table Machines
    Last Post: 03-21-2008, 05:06 PM
  5. 4th axis resolution requirements?
    By KDN Tool in forum Benchtop Machines
    Last Post: 09-21-2005, 08:43 PM
