585,977 active members*
4,235 visitors online*
IndustryArena Forum > Machinery Manual, Brochure / Photo Archives > Machinery Manuals / Brochures > CNC-1310 Machine Z-Axis keeps going Upwards not into material!
    Dec 2012
    4
    I use inkscape to make simple shape for engraving, makercam to generate GCode for the same, when sent thru grblControl 0.8.4 to CNC-1310 C Machine, it starts engraving normally, on second pass of engrave, the z-axis is moving upwards
    not downwards through the material, no engraving!
    Many thanks :wave:
    Apr 2014
    215
    Which way is the z axis motion going?
    Is it positive or negative?
    G1 Zxxx or G1 Z-xxx
    The normal way is downwards is negative motion (think XYZ plane, Z- is down)
    If the Z-axis gcode is negative, your machine is setup wrong, and you need to change the axis direction within grbl.
    If the Z-axis gcode is positive, your post processor is setup wrong and you need to change your post processor settings.
    Learn to read the gcode
  1. Quill fit upwards tolerance, opinions???
    By rolfinator2002 in forum Bridgeport / Hardinge Mills
    Last Post: 06-29-2023, 02:40 PM
  2. Replies: 3
    Last Post: 12-19-2012, 02:59 AM
  3. 3 axis, NC code run machine to cut Plastic material
    By karan_kulkarni in forum DIY CNC Router Table Machines
    Last Post: 07-21-2010, 10:45 PM
  4. Z axis shaft material
    By andy_ck87028 in forum Mechanical Calculations/Engineering Design
    Last Post: 05-16-2005, 01:46 PM
