585,727 active members*
4,028 visitors online*
IndustryArena Forum > Community Club House > General Off Topic Discussions > Wax Brass Stamp : What bit shall i use? best software!
Results 1 to 7 of 7
    Dec 2012
    4
    Hi there
    I need to make Brass Wax Stamp, similar to the attached photo, i have the blank Bass heads, 23 & 30 mm diameters.
    What software free/paid can achieve fine details of these stamps? And what are out there the matching bits for these fine details engraves!
    I appreciate your time reading this.
    thanks
    Apr 2005
    304
    Re: Wax Brass Stamp : What bit shall i use? best software!
    Vectric Aspire
    Make no mistake between my personality and my attitude.
    My personality is who I am. My attitude depends on who you are.
    Apr 2014
    432
    30 deg or 60 Deg I used ,I looked into making them $2 outa china with a nice handle I can't buy brass for the price they are charging have fun this is the key to life.
    Apr 2004
    5734
    Those bits would work better for that project if you stoned the tips down to a rounder profile. If they're extremely sharp, then you'd have to put the tool passes very close together to avoid a striated surface. Or you could use a small ball-nose cutter.
    What kind of software are you looking for? Is it to make the models, or to translate pre-existing models into tool paths? These are different sorts of programs, although you'll sometimes see both functions combined in a single package.
    Andrew Werby
    Website
    Dec 2012
    4
    thank you, Andrew Werby
    your ideas are great, i am using Vectric Aspire, it is awesome. i am intending to grave letters and simple shapes into 0.5 mm brass/copper heads.
    Dec 2012
    4
    Quote Originally Posted by ZASto View Post
    Vectric Aspire
    Correct, it is great program.
    Apr 2003
    540
    The v-bits will work great, You may want to remove any material and the flats you can with a 1/16 or so flat bottom or ball end mill to cut down on the machining time, then finish cut with the end mill. Aspire or Artcam
    would work great for this project. So would v-carve I'd imagine. Inventor with HMS would also work great but has a higher learning curve. Have fun!
  1. Making Iron Heat Stamp on Brass - V Carving on brass with 20 degree V-Bit
    By kostas1 in forum Metalworking- / Woodworking Tooling / Manual Machining
    Last Post: 03-02-2018, 05:00 PM
  2. Chinesse Machine, need a stamp software
    By narkko in forum Laser Control Software
    Last Post: 08-23-2015, 09:45 PM
  3. Replies: 4
    Last Post: 02-27-2015, 04:50 PM
  4. HX3040 Stamp software?
    By CanAm in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-18-2009, 02:06 PM
