584,814 active members*
5,215 visitors online*
    Jun 2017
    369
    Dust collection mod question
    I purchased harbor freight 2hp dust collector, Weinn industries filter and a super dust deputy to do the mod that everyone seems to be doing on YouTube & everything seems to be going ok but my issue is this.
    My building that the router is in has a low ceiling and once the weinn filter is installed with the filter inlet in line with the exhaust port of the dust collection motor it will need to be removed everytime the drum needs emptied.
    Does the inlet need to be in a straight line with the exhaust? If I raise it up to the ceiling I could get the drum out without removing the weinn filter.
    Thank you
    Gary
    I'm not sure why the photo is rotated it is correct in my gallery
    Attachment 406480
    Dec 2013
    5717
    Re: Dust collection mod question
    Normally the blower/motor system can be located anywhere, so you could have it located to the side of the cyclone and connected with an elbow, so any plumbing that would get it out of the way would work. But keep in mind that each elbow slightly reduces the system airflow.
    Jim Dawson
    Sandy, Oregon, USA
    Jun 2017
    369
    Jim, ok thank you. I'm going to see how far out of the way I can get the filter.
    Thanks again
    Gary
    You can put the filter anywhere, but the straighter the better. Try to avoid 90° bends.
    People do what's known as the "Stovepipe Mod" to reduce restriction between the blower and filter.
    https://www.sawdustzone.org/forum/di...-stovepipe-mod
    Jun 2017
    369
    Gerry - Thank you I'll use the stovepipe mod. Even if it doesnt get the filter out of the way enough to keep me from having to remove the filter it seems to make a big difference in performance.
    Thanks again
    Gary
  1. Help with dust collection
    By AJ Negvesky in forum Joes CNC Model 2006
    Last Post: 01-31-2017, 09:00 AM
  2. Dust collection : Dust deputy, clearvue min etc. - need some help
    By FoxCNC1 in forum Uncategorised WoodWorking Machines
    Last Post: 03-08-2015, 02:26 PM
  3. Sensing dust level in dust collection bin
    By DonFrambach in forum DIY CNC Router Table Machines
    Last Post: 04-07-2013, 10:26 PM
  4. Dust Collection
    By signpro in forum Joes CNC Model 2006
    Last Post: 02-14-2012, 02:38 AM
  5. Dust Collection
    By sonicwonder2000 in forum DIY CNC Router Table Machines
    Last Post: 03-23-2010, 03:57 PM
