Looked at between pump motor and pump to find gearbox oil pump flex coupling #93-30-5725 cracked and broken.
Replaced with new part #93-30-5725. Still #179 Low Transmission Oil Pressure Fault.
Checked to make sure pump motor and pump is spinning which is confirmed.
Cleaned dirty oil strainer. Still #179 Low Transmission Oil Pressure Fault.
Pump is running but not pumping oil as seen through clear oil lines with no oil in in. Tried different ways to prime pump but oil does not flow.
Need new pump or something I'm missing to prime the pump to get the flow started?
Thanks everyone in advance.
Thomas
