585,753 active members*
4,299 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > CNC Wood Router Project Log > can i fix this directly from the cnc softwars (GRBL / LINUXCNC / MACH3 )?
    Exclamation can i fix this directly from the cnc softwars (GRBL / LINUXCNC / MACH3 )?
    Hello, friends, I have some questions. I hope you will help me in answering them.
    Yesterday I finished making my CNC machine table but there are some mistakes in the measurements because the iron bar I used was not 100% straight.
    This simple diagram shows the place of simple curvature in iron bar.
    https://files.fm/u/knuw8wwx#/view/cnc.jpg
    My question is whether i can fix this directly from the cnc softwars (GRBL / LINUXCNC / MACH3 ) or i should make a new table . and thank you for help
    Mar 2008
    683
    Re: can i fix this directly from the cnc softwars (GRBL / LINUXCNC / MACH3 )?
    1cm seems like a lot. Cut the bar and re weld it to a closer tolerance. Then use a spoil board that you can machine flat. That's about how every CNC is made.
  1. can i fix this directly from the cnc softwars (GRBL / LINUXCNC / MACH3 ) ?
    By abdelkrim30 in forum Open Source CNC Machine Designs
    Last Post: 11-26-2018, 01:38 PM
  2. Arduino GRBL VS LinuxCNC
    By valmar in forum DIY CNC Router Table Machines
    Last Post: 01-15-2018, 05:50 PM
  3. GRBL logging with linuxcnc.
    By samco in forum OpenSource Software
    Last Post: 06-04-2015, 02:21 PM
  4. grbl vs mach3 vs linuxCNC
    By speed_racer in forum Benchtop Machines
    Last Post: 05-08-2015, 02:37 AM
  5. Should I use LinuxCNC or grbl/arduino?
    By CptanPanic in forum LinuxCNC (formerly EMC2)
    Last Post: 04-23-2012, 07:06 PM
