Originally Posted by
maver1ck
I lived in England installing machines for a while and can think of a couple guys in Leeds and Birmingham that may be able to help you, but its been a while since I've talked to either, so not sure if they are still available.
The blue screen you described sounds like the hard drive was likely corrupted. As I indicated I the last post, it is likely occurred when someone was working on another issue since the most common cause for this is someone shutting the machine off before Windows has completed a successful shutdown. I have also seen cases where a power outage can cause this so it is possible the hard drive is your on the issue but based on your description seems unlikely.
I have a computer specifically setup for hard drive recovery, and I can frequently salvage and recover the information from the hard drive, but since I doubt you have access to this, would probably be easier foe you to just replace the hard drive.
Another thing to consider is I have had several shops send their PCA to me to test everything and make sure all the basic control components are OK. Depending on what you know about the history, this may be the quickest way to get through all the unknowns.
