585,902 active members*
4,085 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > Disabling single stepper on G540 drive
    Nov 2018
    Hello,
    I am using a Gecko G540 drive (with an Arduino-like PLC, Controllino) to drive 3 steppers. Is there any way to disable a single stepper out of the 3 and let the two others run normally ? (I need to disable one stepper so that it doesn't prevent another one from rotating).
    I have looked on this forum, and on the internet but with no success.
    Thank you all for your help.
    Best regards,
    Nov 2012
    1267
    Re: Disabling single stepper on G540 drive
    So you need to deenergize the disabled motor? Then the answer is no, unless you modify your G540. It has a single /ENABLE input for all 4 motors.
    Dec 2013
    5717
    Turn off the power, disconnect the stepper motor from the controller, turn the power back on, and you should be good to go.
    Jim Dawson
    Sandy, Oregon, USA
