585,975 active members*
4,437 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2) > linux cnc 4 axis machine definition / post problem... bad chjaracter "A" used
    Oct 2012
    22
    Arrow linux cnc 4 axis machine definition / post problem... bad chjaracter "A" used
    Hello. Thanks for looking at my problem.
    linux 2.4.5
    I'm using a smithy sherline cnc. Bobcad v31 4 axis.
    I have the correct bobcad post processor (I think) but when I try to load the gcode file onto my machine I get the error.
    line 21...file name/ bad character "a" used.
    The file will not even load onto the machine.
    I think that A axis is :
    not defined in linux on machine.
    or
    controller can't read 4 decimal digits for a rotary axis
    I have looked at the hal configuration and A axis there under parameters.
    Do you have to enable A axis in linux ? If so where?
    jc
    May 2005
    1662
    Re: linux cnc 4 axis machine definition / post problem... bad chjaracter "A" used
    The number of trailing digits after the decimal shouldn't matter or at at least it doesn't on my machine.
    It's configured in INI and HAL. If you used stepconf this should have been done for you.
    If you use the AXIS interface do X Y Z & A all appear in the coordinate readouts ?
    Anyone who says "It only goes together one way" has no imagination.
    May 2015
    686
    Version 2.4 is pretty old. Current version is 2.7.
    Does the A axis appear in your GUI?
    Rod Webster
    www.vehiclemods.net.au
  1. Replies: 2
    Last Post: 01-22-2018, 10:35 PM
  2. EZ PATH S: STRANGE MACHINE LIMIT PROBLEM (what is the mystery "9")
    By Cortazar in forum Bridgeport / Romi Lathes
    Last Post: 12-27-2014, 06:46 PM
  3. X Axis "Goes Off Pattern", "Awry", "Skewed", "Travels"
    By DaDaDaddio in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-06-2013, 09:59 AM
  4. Definition of "minimum shaping character"?
    By spincaster in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 07-07-2012, 11:27 AM
  5. Thread Milling using "C" axis no "Y" on the machine
    By tejano4life72 in forum Mori Seiki lathes
    Last Post: 07-19-2010, 08:59 PM
