585,975 active members*
4,537 visitors online*
    Nov 2018
    Retro fit kit
    I have a Sab 1000 optical tracing system and table, the tracing system doesn’t work anymore, so I want to install a kit, motors, controllers, with breakout board to be able to operate the plasma table from a computer.
    Can anyone help, with finding a quality kit around $300 dollars.
    I so confused about what I need in a kit, and Google has me overwhelmed with a the cnc kits.
    Thanks in advance
    Ronnie
    Dec 2013
    5717
    Re: Retro fit kit
    I would start by figuring out what motors are currently driving the machine. Maybe you can use them and the drives. If using them is not an option, you need to at least look at the specifications on them to be able to properly spec the new motors.
    Jim Dawson
    Sandy, Oregon, USA
    Nov 2018
    Re: Retro fit kit
    Thanks Jim, for giving me direction on what to start with, I will get the spec on the motors, I think they are stepper motors, and I think they are rated in ounces, am I right about that.
    If I can get that information then I think information on controllers is next.
    I really appreciate your help
    Ronnie
    Dec 2013
    5717
    Re: Retro fit kit
    The motors would be rated in oz/in or Nm. If they are steppers that is the holding torque. If the drives are still good you may be able to use them also, along with the power supply. The difficulty in using them may be in wiring everything up to a new breakout board, just depends on how the current system is wired up.
    Jim Dawson
    Sandy, Oregon, USA
  1. CNC retro fit
    By jonesr in forum Mechanical Calculations/Engineering Design
    Last Post: 03-08-2011, 07:15 PM
  2. To retro or not to retro (fit)
    By Mr. LocoMartin in forum HURCO
    Last Post: 03-05-2009, 04:44 AM
  3. BP BTC II Retro
    By DennisCNC in forum Vertical Mill, Lathe Project Log
    Last Post: 06-26-2008, 01:49 AM
  4. TM-5 for Retro in OKC
    By mlogical in forum HURCO
    Last Post: 04-09-2008, 06:09 PM
  5. Help retro fit bp cnc
    By arrowglide in forum Bridgeport / Hardinge Mills
    Last Post: 05-04-2005, 02:36 AM
