585,978 active members*
4,397 visitors online*
    Dec 2015
    8040m z-axis servo error code 1211
    Needing some assistance in figuring out this z-axis servo error code 1211,
    I've Googled and found a couple of things to try like checking the wiring and connections with no luck,
    Any help would be appreciated,
    Jan 2019
    Did you get to the bottom of this? I'm stuck in the same situation. The manual doesn't even seem to have a chapter on error codes.
    Dec 2015
    Quote Originally Posted by Blankestslate View Post
    I ended up calling Fagor, it's a following error and ended up being a bad servo motor
  1. Replies: 3
    Last Post: 04-23-2015, 08:19 PM
  2. Vision Servo Driver Error Code?
    By DMaz in forum Daewoo/Doosan
    Last Post: 01-11-2013, 04:30 PM
  3. ISO CODE MANUALLY INPUT ON 8040M
    By mousongie in forum Fadal
    Last Post: 11-16-2012, 04:42 PM
  4. 414 servo error code Bridgepoint VMC 1000
    By drchris123 in forum Bridgeport / Hardinge Mills
    Last Post: 11-08-2010, 05:42 PM
  5. Error 414 Z-axis error detect servo alarm
    By andywids in forum Uncategorised MetalWorking Machines
    Last Post: 07-09-2009, 03:56 PM
