585,982 active members*
4,648 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > Hurco Hawk 2u Hard drive bad with ultipath Software
Results 1 to 11 of 11
    Hello,
    Can any one help me. I have this small Hurco Hawk 2u
    The control is ultipath
    now the hard drive was bad in this when i got it and i have been using it as a manual mill for 6months or so but i want to get the cnc up and running now
    The hard dive will not boot I have had the hard dive recovered and got as much data of it as i can. I have got a new hard drive in to it and loaded windows 98 (i belive the original was Windows 95 but i didnt have this) and it boots up windows. I have then copied all the dater from the old hard drive over and i can open the sortware but seams that only some bits of it work so i think to much is missing.
    I have spoken with hurco and they seam to know nothing about this type of controller now. however they have send me 2 floppy disk (ultipath masters)
    Disk one has Continue Execprog.001 and hurco.LDR on it
    Disk 2 has execprog.002 and led_ed.LAN on it
    I have tryed to boot these disks on Windows 98 and nothing happens
    it seams that this controller from what I have been reading is verfy simuler to BMC30 but with a windows .... Is this correct? and if so do I load the software in the same kind of way?
    I have found this https://docs.google.com/document/d/1...Byszi9LLU/edit
    That says how to load a BMC30 and the files and names seam to very very simuler....
    but if i need two partitions one C:/EXECUTIVE_1 and one D: /PART_PROGS where has windows got to be installed?
    I do now have a copy of windows 95 that i can try but any help would be greatly appreciated from any one that knows any thing or that has one of these that might be able to help with DATA
    I would like to try every thing i can on this controller before considering a retro fit
    Thank you in advance
    Re: Hurco Hawk 2u Hard drive bad with ultipath Software
    any help any one?
    Jun 2008
    1104
    It’s been a long while since I worked on an Ultipath control. By the sounds of it, you may have the wrong disks for it. Where are you in the world?
    Hi Bloke.
    Thanks for responding to me. I am in the Uk
    I have been doing some diging on this again to night and it looks like you are right I think I have the wrong disks.
    When I had the original drive recovered I got most of the data off but I am missing some on the files that seam to be needed to make the software run. What i need is somone with the disks of a hard drive I can copy.
    What do you remember of the ultipath controll? where are you in the world?
    Thank you for your help
    I am based in norfolk near norwich.
    Jun 2008
    1104
    I’m in Bucks. I’ll see if I can find some disks in the office. I should be back there tomorrow morning.
    amazing thank you. do you work for hurco?
    Jun 2008
    1104
    Good news! I had a trawl around my laptop and found two versions. PM me a mail address and I’ll bang ‘em over to you.
    Yes I do.
    amazing. thank you. so much. pm sent
    Mar 2012
    I have just picked up on this thread I may have the discs you need and if you need any help i have a fully running 2 axis U2 but best of all I am 24 miles from Norwich give me a call if I can help in any way
    Gordon
    01952483640
    Hi Gordon. thanks for getting back to you
    I tried to call you but number seams to be wrong
    would be nice to talk to you
    mine is 07769721170
    kc
  1. Hurco SSM20 w/ Ultipath control
    By AudioAnonymous in forum HURCO
    Last Post: 07-21-2020, 12:34 PM
  2. Replies: 0
    Last Post: 01-23-2017, 09:28 PM
  3. Hurco BMC40 Hard Drive Replace
    By regocolm in forum HURCO
    Last Post: 11-16-2016, 08:19 PM
  4. hurco hawk spindle drive problems
    By nealg in forum HURCO
    Last Post: 10-02-2014, 11:16 PM
