585,712 active members*
3,964 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion > Advice on Bearing for 24" Rotary Table?
    Nov 2018
    53
    Hello!
    I'm working on a project that will have a 24" diameter steel plate that need to rotate smoothly. Can someone suggest some options regarding bearings? Prefer not crazy expensive. I've looked at some axial bearings.There will be around 100-150lb on top.
    Randy
    PS This will be a horizontal table. Like a turntable.
    Dec 2013
    5717
    Re: Advice on Bearing for 24" Rotary Table?
    How about a heavy truck tapered wheel bearing, normally the inner bearings are pretty large.
    A little less accurate but cheap https://www.vxb.com/1000-lbs-Capacit...-p/kit8999.htm
    Jim Dawson
    Sandy, Oregon, USA
    Nov 2018
    53
    I was thinking automotive. Thanks, I'll check that out.
    Nov 2018
    53
    Jim, taking your advice I went with a Dodge RAM 3500 wheel hub assembly (new), on ebay for $30 shipped.:-) it's a bit stiff but plenty rigid. Thanks
    I may buy a rotor to use as a mounting plate.
    Dec 2013
    5717
    Happy the hear it will work for you. $30 is a heck of a deal. It will loosen up after a few hundred miles
    Jim Dawson
    Sandy, Oregon, USA
  1. Pros and cons of rotary table sizes: 6" vs 8"
    By dbruins in forum Tormach Personal CNC Mill
    Last Post: 01-09-2015, 08:59 PM
  2. Replies: 17
    Last Post: 02-22-2014, 06:58 PM
  3. 6" or 8" Rotary Table for 4th axis on G0704?
    By bogiestl in forum Benchtop Machines
    Last Post: 01-31-2012, 03:33 PM
  4. Rotary Table Size: 8" vs 10"
    By Dave.Kellogg in forum Charter Oak Automation Support Forum
    Last Post: 11-12-2010, 11:24 PM
  5. "Lathing" with a rotary table?
    By JMcDonald in forum Benchtop Machines
    Last Post: 10-13-2007, 10:47 AM
