585,959 active members*
4,867 visitors online*
    Nov 2016
    62
    PathPilot induced crash
    Just a quick warning about PP 2.1.15...
    Conversational was updated to "optimize" the gcode and save unnecessary moves, like when facing and then outside chamfer with the same tool. It does this by commenting out the spindle shutdown and coolant off commands (M5, M9) and then commenting out the G30.
    If you manually edit the code to add a tool change before the next ops M1 (for applying tapping fluid, for instance), and THEN re-edit anything in conversational, it will "optimize" the M5, M9, and G30 right above the tool change.
    I recommend you open your code in gedit, search for "T0" and make double sure there is a G30 right above it, unless the sequential operations share the same tool and you are okay with the optimization.
    I've shared this with the FB group and wanted to make sure it got out to as many people as possible.
    Jun 2006
    3063
    Re: PathPilot induced crash
    Hopefully, you also reported it to Tormach.
    Nov 2016
    62
    Of course.
  1. PathPilot 2.x and PathPilot Simulator
    By draper-ballou in forum Tormach PathPilot™
    Last Post: 01-01-2019, 01:42 AM
  2. pathpilot crash
    By jeffrey001 in forum Tormach PathPilot™
    Last Post: 06-03-2017, 07:49 AM
  3. PathPilot Lathe (1.9.4b) - Didn't prompt for tool change = CRASH!
    By brianbonedoc in forum Tormach PathPilot™
    Last Post: 06-06-2016, 08:26 PM
  4. Noise problem, induced by VSD-E?
    By lfleiva in forum CNC Machine Related Electronics
    Last Post: 02-08-2010, 10:39 PM
  5. induced voltage danger?
    By Oaktreeman in forum Community Club House
    Last Post: 05-25-2006, 05:12 AM
