585,969 active members*
4,521 visitors online*
    Mar 2014
    1131
    Help me understand CPR
    So I have an AC servo with a custom commutation encoder installed. Now I'm setting the motor and encoder on ABB's Mint WorkBench.
    The encoder is 10 pole commutation 1024 cpr incremental encoder with hall.
    In the Drive Setup menu>Feedback page there is an entry for CPR (Resolution). The value I need to enter is probably 1024/4 = 256
    However, what confuses me is the data on the pdf of the encoder. The encoder has 1024 cpr however in the timing diagram it says:
    (360 x 4) / cpr = 1 cycle (1 rev?)
    so:
    (360 x 4) / 1024 = 1,40625 cycle
    I'm really confused. I need some help here. What is my cpr? 1024 or 360 x 4 = 1440 ?
    Mar 2014
    1131
    Re: Help me understand CPR
    Got it working. Correct CPR is 256 x 4 and I had to set all scale factor values to 1.
    24221
    Quote Originally Posted by Azalin View Post
    So in this case the correct description of encoder resolution is always the basic CPR, which is '"256 cpr incremental encoder with hall"
    Al.
    Albert E.
  1. G41 and G42 understanding
    By muhndkalel in forum G-Code Programing
    Last Post: 03-27-2017, 12:00 PM
  2. need some understanding for PP
    By ward2699 in forum SheetCam
    Last Post: 08-21-2016, 01:43 AM
  3. Help understanding G28 w/ Fanuc
    By mbam in forum Cincinnati CNC
    Last Post: 05-30-2014, 02:43 AM
  4. Help Understanding “following errors”
    By Cellar Dweller in forum Bridgeport / Hardinge Mills
    Last Post: 01-17-2012, 01:39 AM
