585,676 active members*
5,522 visitors online*
    Sep 2014
    66
    roundover bit 25.4mm
    HI. I am considering using a 1" (25.4mm) roundover bit - without the bearing, see photo.
    For feeds & speeds how should I think of it? V-bit, End mill, form bit?
    In ferreting out info from various sites the speeds & feeds are frightening to me .
    Any advice appreciated.
    Thanks.
    Re: roundover bit 25.4mm
    Assuming your cutting wood, try 12,000-14,000 rpm, and 100-150ipm.
    Sep 2014
    66
    Thanks.
  1. Radius router bit for roundover fillet?
    By j_omega in forum DIY CNC Router Table Machines
    Last Post: 11-16-2018, 03:51 AM
  2. Replies: 4
    Last Post: 08-07-2015, 05:19 AM
  3. 3d contouring possible with a roundover bit?
    By alex781 in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 09-05-2010, 01:41 PM
  4. online source for plunge roundover bits?
    By groomden in forum DIY CNC Router Table Machines
    Last Post: 04-25-2009, 03:33 PM
  5. Tool Library and Roundover Toolpaths
    By Natchamp in forum Visual Mill
    Last Post: 07-12-2004, 02:53 PM
