586,005 active members*
4,897 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion > Need advice on belt selection HTD 8M?
    Nov 2018
    53
    So, I'm about to order 5 meters of belt. I'm going with 25mm wide for my application. I'm currently looking at HTD5M or HTD8M. I know the number is the pitch. I found some good prices. I'm having a harder time finding a pulley.
    At 25mm wide, is there a different belt type that may have more pulley options (inexpensive options).
    This is not high speed. Just weight and a long run.
    No point in getting inexpensive belt and having to pay $$$ for a custom pulley.
    Thanks So, Much.
    Randy
    Dec 2013
    5717
    Re: Need advice on belt selection HTD 8M?
    Try Ametric https://www.ametric.com/s-274-htd.aspx
    They also sell belts and just about any other power transmission product you could want.
    If you'll give me the specs, I'll try to help you spec the correct one. Wading through their catalog can be a little daunting.
    Jim Dawson
    Sandy, Oregon, USA
    Jun 2018
    362
    Just curious if the 25mm width will be enough to account for the weight of the head and possible stretch over time. Clay is heavy - yes? If the height is 2 metres that's about a 4 metre length if its a full loop.
    The belt would be under constant tension - right?
    I may be way off base but your machine sounds like its either a clay additive or is it for shaping clay on the rotary table?
    Would love to see some detailed photos or sketches.
    Cheers,
    HarryE.
    Nov 2018
    53
    Jim, I'll definitely take you up on your offer in help with selection when I have things figured out more. I have the motors coming in. I'm going to order the belt. I need to feel everything and see how close I am from my design.
    And Harry, I will definitely follow up here on my build. Everyone here has been so helpful and supportive. The printer has a RAM extruder like a big syringe to extrude the clay.
  1. Material selection advice
    By idris in forum Glass, Plastic and Stone
    Last Post: 11-23-2012, 06:26 AM
  2. belt profile selection vs. motor torque
    By johngalt47 in forum DIY CNC Router Table Machines
    Last Post: 06-20-2011, 09:32 PM
  3. HELP - Belt/Pulley Selection - What Pitch? too many choices!?
    By Ducatikid in forum Linear and Rotary Motion
    Last Post: 01-20-2011, 07:15 PM
  4. Advice on motor selection
    By andrew888 in forum RC Robotics and Autonomous Robots
    Last Post: 12-19-2007, 03:30 PM
  5. Need advice w/ encoder selection
    By bdillard in forum Mach Software (ArtSoft software)
    Last Post: 03-12-2006, 03:36 AM
