585,969 active members*
4,354 visitors online*
IndustryArena Forum > CNC Electronics > Hobbycnc (Products) > Amps vs motor vs controller?
    Jun 2010
    28
    Hello,
    I have a 4.3 amp 4 axis controller and wondering about wiring the 34 stepper motors in series=3.2 amp or parallel=6.3 amps.
    Its seems like a no brainer question but I have to ask incase of other variables Im not aware of.
    Just a hobby machine.
    Thank you
    Jas
    Re: Amps vs motor vs controller?
    It actually depends on a lot of other things.
    While it will only have 68% of the torque when wired parallel, it may still outperform series if you need higher speeds, and the 68% is enough to do the job.
    Jun 2010
    28
    I don't think ill need high speed which I guess I wont know without a actual speeds, one of my roughing tools paths top speed is 50ipm with a 50% on a .25 bit and a 1/4 cut depth. Its mostly for carving type work. The machine is about 53X53 cutting area with a rotary on the end. Singles on XZ and dual motors on Y. The only catch is the huge spindle weight. Im guessing >25lbs and the gantry is +80lbs.
    I just don't want to smoke anything.
    Jas
  1. amps required for controller
    By Linrox in forum Australia, New Zealand Club House
    Last Post: 10-31-2016, 03:56 AM
  2. What amps for a x3 dc motor
    By hudmut in forum Uncategorised MetalWorking Machines
    Last Post: 01-15-2009, 05:32 PM
  3. 1-axis on controller and need to drive two amps
    By AKFALAR in forum Controller Cards
    Last Post: 12-20-2008, 05:29 AM
  4. 2.5 amps per phase drive - 2.8 amps per phase bipolar motor ...
    By kochevnik in forum Stepper Motors / Drives
    Last Post: 10-23-2006, 04:48 AM
  5. Stepper controller that can handle more than 8 amps
    By ngr1 in forum Stepper Motors / Drives
    Last Post: 10-03-2005, 04:47 PM
