584,874 active members*
5,187 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Avid CNC > CRP4896 Standard to Linear Rail Conversion
Page 5 of 5 345
Results 81 to 99 of 99
  1. #81
    Apr 2016
    841
    Re: CRP4896 Standard to Linear Rail Conversion
    While not everyone likes them, I'm a big fan of t-track for clamping. Lot's of versatility and substantial holding power. Orange Aluminum sells 8' lengths for $17.08 and provides free shipping on orders over $100. I found 4" OC to be the perfect spacing. I use hard Maple for my clamp elements. Way cheaper than commercial products and works as well or better.
    Gary
  2. #82
    Feb 2005
    829
    I have had t-track in the past, it was always getting full of dust, so every time I tried to use it had to clean it all out. These are just straight up thru holes with 1/4-20 threads in them. never get packed.
  3. #83
    Apr 2016
    841
    Quote Originally Posted by nlancaster View Post
    Interesting. I have never had an issue with dust collecting in the tracks. I'm guessing I may have a more efficient dust collection setup.
  4. #84
    Feb 2005
    829
    Two issues, one I didn't have very good dust collection. Another issue, the builder of my first CNC machine, a JoesCNC 2006, put the track in with sheet metal screws, so I ended up pulling them out of the wood.
  5. #85
    Apr 2016
    841
    If you ever to give t-tracks another shot, try using machine screws, washers and nuts to fix them. You'll never pull them loose. Also, check my build thread on the subject. The way I did it, you don't need screws of any sort. I used them anyway, but I didn't need to.
    Gary
  6. #86
    Feb 2005
    829
    Installed spoilboard and spend more time tramming machine. Trammed Z-axis Vertical to the best of my ability and trammed spindle to within .001 over a 12inch span in X and Y axis.
    Surfaced spoilboard and first project cuts will be Sunday, I will try and take some video.
  7. #87
    Feb 2005
    829
    Machine is working great, best edge cut quality I have ever had on acrylic, smooth to the touch!
    https://youtu.be/Da3stJWhyLg
  8. #88
    Feb 2005
    829
    Diamond drag sign also worked great, had to use exact stop mode to get the engraving to have sharp corners.
    https://youtu.be/UhYz501UEWs
  9. #89
    Apr 2016
    841
    Nice sign!
    Gary
  10. #90
    Feb 2005
    829
    Thanks!
    I will say, the BLH rails seem to have been a good bet. Very smooth and stiff.
  11. #91
    Apr 2016
    841
    Thanks!
    Glad you like them. You mention "stiff." What's the preload? I've never seen a Chinese that was other than light, but then, I haven't spent a lot of time comparing them. My Taiwanese are medium preload.
    Gary
  12. #92
    Feb 2005
    829
    These are medium preload, which I understand is the preffered preload.
    The stiffness I am refering too is basically no play in the system, I am already getting better cut quality then I ever did before.
  13. #93
    Apr 2016
    841
    Yes, I believe medium preload is preferred. I'm happy I chose medium.
    My first machine also used the skate bearings. World of difference moving up to linear rails.
  14. #94
    Feb 2005
    829
    Money making work for an online acquaintance.
    ATP5 tool plate .750in Drilled with .250 stubby drill, .250 hss single flute 60ipm helical bore for countersinks and thru holes, .375 hss single flute 60ipm .060 doc slotting for profile. .375 hss single flute 60ipm .750 doc .003 stepover for finish pass.
    All chamfers done on the machine with a single flute .250 chamfer tool.
  15. #95
    Jan 2016
    69
    Looks great!!
  16. #96
    Sep 2020
    merhaba cnc router kendim yapmak istiyorum ama broje gerekıyor sizde varsa yardımcı olurmusunuz 1500x3000
    [email protected]
  17. #97
    Oct 2022
    Hi Nick, who did you use for the anodizing?
    Thanks!
  18. #98
    Nov 2013
    Hi, I was wondering who you used for the anodizing? Thank you!
  19. #99
    Apr 2016
    841
    Quote Originally Posted by Techson View Post
    I didn't have my parts anodized. I used 6061 t6 aluminum. Since I have the CNC in a temperature controlled spaced (heat and AC) I haven't had any adverse effects from not anodizing.
Page 5 of 5 345
  1. Replies: 99
    Last Post: 08-10-2022, 02:12 PM
  2. Standard linear motion conversion to linear rails.
    By bobmagnuson in forum Avid CNC
    Last Post: 03-25-2022, 09:52 PM
  3. G0704 Linear Rail Conversion
    By BTP in forum Benchtop Machines
    Last Post: 07-14-2019, 01:59 AM
  4. Sieg X3/SX3 Linear rail conversion
    By DvG4 in forum Benchtop Machines
    Last Post: 01-16-2011, 02:17 AM
  5. Mixing Preloaded&Standard linear trucks on same rail -pros and cons ?
    By isvflorin in forum Linear and Rotary Motion
    Last Post: 01-13-2009, 06:05 PM
