Re: How do you cut your raw steel and aluminium stock?
For cutting aluminum I use one of my Evolution saws , one small chop saw with a roll case, one larger hand held. I have used the Evolution saws on mild steel and stainless, but the blades don't live long in stainless, seems to do OK in mild steel. I also have an Evolution blade in my table saw for cutting aluminum plate, but you have to be very careful when doing that.
Sometimes I use the abrasive chop saws for steel, but I really don't like them. They work OK with a good Norton wheel, not so good with an import wheel.
Most of the time I use the horizontal band saw for longer material, for shorter material maybe the vertical band saw.
If I don't feel like dragging a full bar of steel angle or something like that into the shop to cut in the bandsaw, I might use the port-a-band to slice off what I need in place.
The only time I use a angle grinder for a cutoff is when I can't really use any other tool to do the job.
Have been thinking about buying a cold saw.
Jim Dawson
Sandy, Oregon, USA
