586,000 active members*
4,997 visitors online*
Thread: STL File?
Results 1 to 8 of 8
    Jan 2012
    163
    STL File?
    I have this stl file to make this easy say the image is 2.00 x 2.00 and I what to make it 50% smaller 1.00 x1.00 and remember this is a STL file of a image what can I use and how can I resize or reduce the image size?
    Thanks any help would be great!
    Feb 2007
    4553
    Re: STL File?
    Quote Originally Posted by rmachinist View Post
    1: Convert STL to DXF
    2: Scale DXF to desired size
    Have a most awesome evening!
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    Jan 2012
    163
    Re: STL File?
    Convert 3D STL to DXF scale it and Convert DXF back again to STL to cut it in 3D? and what program can i use for this?
    Feb 2007
    4553
    Re: STL File?
    What software did you use to create the STL?
    Re: STL File?
    Most CAM software can scale the .stl before creating toolpaths. No changing of formats is necessary.
    Feb 2007
    4553
    Re: STL File?
    I completely agree with what Gerry said, please post information about what software you are using so someone here may provide pertinent information, direction and help.
    Jeff...
    Apr 2004
    5737
    Re: STL File?
    When you say this is an STL "of an image" - does that mean you've created a heightmap mesh from a bitmap? Or are you trying to save a 2D image as a STL (which isn't going to work)?
    Andrew Werby
    Website
    Jan 2012
    163
    Re: STL File?
    i gotten the STL file from (thingiverse) i have GIBBSCAM v12 , freecad, and fusion 360. i use gibbscam for creating toolpaths any help would be great thanks!
  1. How to Merge Init file with external buttons file.
    By amitkumar171 in forum Dynomotion/Kflop/Kanalog
    Last Post: 11-19-2017, 07:14 PM
  2. Replies: 8
    Last Post: 05-04-2015, 12:49 PM
  3. Windows x64 text file splitter that goes by lines, not file size?
    By Galane in forum Uncategorised CAM Discussion
    Last Post: 04-06-2015, 12:26 AM
  4. How do you convert STL file from 3D printer to G-code or a CNC desktop mill file
    By imperial90303 in forum Uncategorised CAM Discussion
    Last Post: 01-25-2015, 08:37 PM
  5. using a data file for both 3D printer and CNC router , Converting file or ???
    Last Post: 12-17-2014, 01:32 AM
