584,814 active members*
5,235 visitors online*
    Feb 2007
    pocketing problem
    Don't know if i should post this in the Mach section or the lazycam. In Lazycam I am using the laser post. When i engrave lines and export to Mach everything works fine. When i use the pocketing function in the lazycam everything looks correct. But when i load it to Mach it adds a bunch of concentric circles to the toolpath. I have also tried Inkscape with the laser plugin and it does the same thing. I don't have this problem with mach on my cnc router but i use mastercam 8 and a different post. I would use that but i can't figure out how to make the post put the M03 and M05 commands in to turn the laser on and off. So i get the laser engraving the radpid paths also. Any suggestions i am pulling my hair out.
    Jun 2011
    692
    Re: pocketing problem
    Pocket is not really a valid laser/plasma toolpath. What you describe is exactly what a pocketing toolpath normally is. Profile, trace, engrave are more the normal toolpath types to be used with laser or plasma.
  1. Problem With Open Pocketing
    By magicniner in forum BobCad-Cam
    Last Post: 11-05-2013, 04:37 AM
  2. Pocketing problem
    By Shinobiwan in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 01-29-2013, 07:02 AM
  3. Pocketing problem
    By gld952 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-01-2012, 03:16 AM
  4. Pocketing Problem
    By Magnum164 in forum SprutCAM
    Last Post: 02-27-2011, 12:51 AM
  5. 2.5D pocketing rapid problem
    By mayhugh1 in forum SprutCAM
    Last Post: 11-02-2006, 08:58 AM
