585,956 active members*
4,560 visitors online*
IndustryArena Forum > MetalWorking Machines > Hardinge Lathes > Hardinge Cobra 42 spindle drive problem
    Dec 2018
    8
    I just replaced my magnatek Gpd 505 drive because it took a dump on me. I bought a Yaskawa A1000 drive for it because they said it was plug and play. I knew it was to good to be true! My issue is the parameters in the drive. I don't know what the parameters are supposed to be in the new A1000 drive and I can't copy them from the old Magnatek GPD-505 because it's fried. The previous maintenance guy never saved the parameters on a log sheet so I'm lost. My book doesn't say anything. Any help would be greatly appreciated
    Sent from my Z982 using Tapatalk
    Mar 2010
    1852
    Re: Hardinge Cobra 42 spindle drive problem
    Get with this guy. He can probably help you out. He has repaired drives for me.
    Zaritron
    Nov 2008
    94
    Did you ever get the YASNAC to work in your Cobra?
  1. Hardinge Cobra 42 vfd problem
    By Dsenterfitt in forum Bridgeport / Hardinge Mills
    Last Post: 12-04-2020, 02:54 AM
  2. Cobra 42 Spindle Drive
    By Jtoothman in forum Mini Lathe
    Last Post: 08-04-2014, 06:50 PM
  3. hardinge conquest 42 VS cobra 42
    By mls in forum Hardinge Lathes
    Last Post: 09-07-2010, 10:42 PM
  4. Parameters on Cobra 42 Hardinge
    By Niall in forum Bridgeport / Hardinge Mills
    Last Post: 07-16-2004, 10:38 AM
