I am upgrading my LMS 3960 Hi-Torque minimill to CNC and I dont know which ballscrews I should get.
The two options are:
1) .625" X .2" with a tolerance of +/- 0.004" over 12"
2) 16mm X 5mm with a tolerance of +/- 0.0012" over 12"
I would surmise that this means for option 1, a workpiece of 1.2 inches would have a tolerance of +/- 0.0004", and option 2 would give me 0.00012"
Now if that is in fact how those numbers translate, I know for a fact that my spindle runout (when measured with an indicator on the end mill shaft) is greater than 0.0004", (in fact it is about 0.0005" for the 3/8 collet)
Mostly I will be machining small parts for robotics, 3d printing and maybe a lower receiver, but nothing that requires crazy tight tolerances afaik.
So is there any point to getting the upgraded ballscrews? Or would they be wasted on this entry-level mill?
Under what circumstances or with what type of work would they be necessary for this mill?
Again, I am not a machinist and I have no training in the field, so feel free to elaborate if you like.
Thanks!
