585,560 active members*
3,287 visitors online*
IndustryArena Forum > CNC Electronics > Rutex Products > Servo Drives > What is the best way to ground a servo motor?
    Mar 2014
    1131
    The power connector of the motor has a pin for grounding but it is not connected. However there is a tapped hole for grounding on the flange.
    I guess the options for grounding are:
    - Connect the gnd pin of the motor internally to the motor case. And that line goes to the drive's grounding input trough the power cable.
    - Connect a single external grounding wire to the hole on the flange and connect other end to ... ? (fill in the ... please)
    24220
    Re: What is the best way to ground a servo motor?
    Any conductor connected to the motor frame is basically needed, the one shown would go to the star point ground connection.
    Wherever the service ground is connected.
    Al.
    Albert E.
  1. Servo motor ground wire and Gecko 320
    By Novett in forum Gecko Drives
    Last Post: 12-30-2014, 02:33 AM
  2. motor com and case ground pro board
    By Ed Williams in forum Hobbycnc (Products)
    Last Post: 03-27-2009, 04:21 AM
  3. New Servo with ground wire
    By Larken in forum Automation Technology Products
    Last Post: 05-03-2007, 12:33 PM
  4. Motor Driver where to put ground?
    By Trapper14 in forum CNC Machine Related Electronics
    Last Post: 08-08-2006, 08:20 AM
  5. Motor supply ground vs Logic ground?
    By Gashmore in forum CNC Machine Related Electronics
    Last Post: 06-07-2005, 11:21 PM
