585,902 active members*
4,074 visitors online*
    Oct 2007
    66
    Labview Kmotion help please
    Hi
    I have just started messing with the Dynomition Kflop board.
    I hope to use the controller with my existing LabVIEW front end but I am having some difficulty getting started.
    I have installed the software package to my pc and run the KmotionCNC.
    All is good, the software sees the board and I can run the Gcode programmes.
    I then tried to run the Labview sample programme Kmotion Dot Net Sample.vi and get the following error
    Constructor Node Error creating instance of KM_Controller in assembly KMotion_dotNet.KM_Controller, KMotion_dotNet, Version=1.0.1.0, Culture=neutral, PublicKeyToken=fcaf9556d6f68c3a, (KMotion_dotNet.DMException: Dll Not Found Exception thrown : Caller - [KMotion_dotNet.KM_Controller] :: Member - [KM_Controller]) <append><b>KMotion_dotNet.DMException</b> in Kmotion DotNet DLL Sample.vi
    I don't really understand what this means, could you offer any guidance please.
    I am running Windows 10 and Labview 2018 32 bit
    Many thanks
    Mike
    Techserv.blog
    May 2006
    4045
    Re: Labview Kmotion help please
    Hi Mike,
    Its saying Labview can't find our libraries. The simplest thing is probably to add our:
    <Install Directory>\KMotion\Release
    to your Windows Path.
    TK
    http://dynomotion.com
    Oct 2007
    66
    brilliant that fixed it.
    Many thanks for your rapid response.
    Cheers
    Mike
  1. .NET + Labview problem
    By copperwr in forum Dynomotion/Kflop/Kanalog
    Last Post: 02-23-2018, 12:44 AM
  2. KFLOP and Labview
    Last Post: 11-02-2016, 04:03 PM
  3. KFLOP + LabView!!
    By TomKerekes in forum Dynomotion/Kflop/Kanalog
    Last Post: 04-05-2015, 06:39 PM
  4. RS 232 communication using LABview for modem
    By nabihahismail in forum Computers / Desktops / Networking
    Last Post: 09-28-2014, 05:38 PM
  5. VIs to allow Labview to drive the G-Rex?
    By wddanie in forum Gecko Drives
    Last Post: 03-11-2007, 08:08 PM
