585,737 active members*
4,498 visitors online*
Results 1 to 9 of 9
    Mar 2007
    16
    What size stepper motors needed?
    I am wanting to modify my Y & Z carriages on 4x8 cnc. I will have approx. 140# for Y/Z carriage. I will be using rack n pinion to move this carriage assembly on v-wheels. I am cutting wood and some plastics. Any ideas as to what size stepper motors I will need to drive this carriage plus having enough torque to cut wood and plastics?
    Gary
    Dec 2013
    5717
    Re: What size stepper motors needed?
    You would be safe with a 1200 oz/in NEMA 34 stepper. Operate them at near the maximum voltage that the drive will handle. That should give you 500 IPM rapids and plenty of torque for cutting. I had a similar system on my router that was a lot heavier than yours with a 1.5:1 belt reduction. Moved the Y at 0.75 inches per motor rotation.
    For steppers, I like the Automation Direct steppers & drives. Not cheap, but they work well. https://www.automationdirect.com/adc...tepper_systems
    You might look at the ClearPath servos, I have had good luck with them. https://www.teknic.com/products/clea...-servo-motors/
    or the DMM servos, I use those also. DMM | AC SERVO DRIVE | AC SERVO MOTOR | ROTARY ENCODER
    Jim Dawson
    Sandy, Oregon, USA
    Are you using any gear reduction to the pinions? Are you building your own drives, or buying off the shelf drives?
    Mar 2007
    16
    I am not planning on any gear reduction. I would most likely buy off the shelf motors, and may have to buy new drives to power the new motors.
    Dec 2013
    5717
    What is the pitch diameter of the gear that you are planning on using to mate with the rack?
    Jim Dawson
    Sandy, Oregon, USA
    You won't get very good motion or performance running direct drive.
    Mar 2007
    16
    ger 21
    Please explain your comment about direct drive.
    Resolution will be very poor, which will result in motion that is not very smooth.
    And you'll need a much bigger motor, as you won't have the benefit of gear reduction, which increases torque at the pinion.
    With steppers, you want between 3:1 and 5:1 reduction, with a 1" diameter pinion. Larger pinions give smoother motion, but require even more reduction.
    Mar 2007
    16
    ger 21
    Bigger motor than Nema 34 1288 oz? How much difference would the drivers make? I am thinking about the Gecko v203's.What motor brands do you recommend? Any and all suggestions are appreciated.
  1. size of stepper motors needed
    By Wyndham in forum DIY CNC Router Table Machines
    Last Post: 09-03-2012, 09:28 PM
  2. Power supply size ??? for Stepper Motors
    By wdysf150 in forum DIY CNC Router Table Machines
    Last Post: 01-19-2009, 08:23 AM
  3. What size Stepper Motors?
    By Oldboy in forum Benchtop Machines
    Last Post: 01-26-2008, 07:14 PM
  4. Stepper Motors size?
    By mtsrose in forum DIY CNC Router Table Machines
    Last Post: 12-14-2004, 05:21 PM
  5. how do i determine what size stepper motors to use?
    By capitalv in forum CNC Machine Related Electronics
    Last Post: 01-20-2004, 09:22 PM
