585,951 active members*
3,912 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Cat30, iso30, nt30, bt30 for benchtop mill.
Results 1 to 6 of 6
    May 2013
    149
    Hi, does anybody have any leads relating to converting Rongfu clone mills to a 30 taper?
    It's a universally copied design (rongfu) and there has to be somebody making a dollar from the conversion.
    Dec 2005
    436
    Re: Cat30, iso30, nt30, bt30 for benchtop mill.
    A long time ago EMCO made some mills that size with a manual tool change for 30 size tapers. They are available used occasionally.
    Your question is good, the problem is usually that taper comes with a gripper system which makes for a big jump in cost relative to a Rongfu with an R8 taper.
    The 30 taper pushes the assembly into an unattractive price point.
    I could be proven wrong(fu) though. (sorry for the bad pun)
    Aug 2006
    671
    charter oak has an optional NT30 spindle upgrade. I'm pretty sure you can buy it separate from the mill. Might be worth a quick phone call if you're interested.
    Manual Square-Column Bed Mills | Charter Oak Automation
    May 2013
    149
    Thanks CS900, that spindle suits RF45 clones, can anybody confirm if an RF45 spindle tube has the same dimension as an RF30/31/32 spindle tube?
    Edit;
    After a bit of google its looking likely that the 75mm quill assembly on the round column and square column are close in terms of design and part numbers.
    Aug 2006
    671
    i would think you could make it work. You may have to replace the bearings to match the new spindle dimensions and the upper bearing location may be off a bit. I'm sure you could make it work.
    May 2013
    149
    The company that sells those are not easy to email replies from, I imagine going in person or by phone would get results.
    Not easy to do from across the pacific ocean.
    Wisdom results from foolishness!
  1. ISO30 or CAT30? tool holders source
    By DigitalDeath in forum DIY CNC Router Table Machines
    Last Post: 08-19-2019, 06:51 PM
  2. ZX4075 BT30/ISO30 Spindle
    By vakeiros in forum RF-45 Clone Mill
    Last Post: 06-12-2018, 01:14 AM
  3. Iso30/bt30 different holder?
    By gary_808 in forum Uncategorised MetalWorking Machines
    Last Post: 10-15-2015, 03:24 PM
  4. BT30 Spindle cartridge for a smithy mill
    By mlennon in forum Maintenance DIY Discussion
    Last Post: 03-12-2013, 05:13 PM
  5. convert SK30/BT30 to int30(ISO30) toolholder
    By HenrikGM in forum Uncategorised MetalWorking Machines
    Last Post: 11-26-2009, 08:43 PM
