585,949 active members*
4,381 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Fadal Mill Z stroke is too short so I can't reach the vice
    Feb 2013
    10
    Sorry if this has been addressed. I tried to find it, but I'm not sure what to search for. I have a Fadal mill. I had to replace the X motor, and when I brought it back online, my Z axis refuses to move close enough to the table to actually cut anything. My Cold start position is fine, and my tool change position works, but Z stokes out a little over a foot above the table. I looked at the SV command, but I don't want to change my tool change position and I'm not sure what is ok to change. It says my Zero offset is -600, but I don't know if that is different than what it was before or what will be effected if I change that. How do I troubleshoot this?
    Sep 2004
    148
    Re: Fadal Mill Z stroke is too short so I can't reach the vice
    Quote Originally Posted by rapitrone View Post
    Is it possible you have a machine with extended Z, and for some reason it thinks it's a machine with standard Z height? You can check what it is in the parameters
    Feb 2013
    10
    Quote Originally Posted by triumph406 View Post
    That was it. It looks like I lost at least some of my parameters. It was set to Z20 instead of Z28.
    Thank you!
    Sep 2004
    148
    Thank you!
    Glad I was able to help!
  1. Short Stroke, 3 cyl turbo diesel
    By mutt_78 in forum I.C. Engines
    Last Post: 07-25-2013, 10:00 AM
  2. F1, motorcycle, short stroke type engines.
    By elmerfud in forum I.C. Engines
    Last Post: 08-17-2009, 07:46 AM
  3. End mill reach !?
    By zaebis in forum MetalWork Discussion
    Last Post: 08-06-2009, 09:24 PM
  4. Tap Stroke Too Short
    By DonK in forum HURCO
    Last Post: 03-25-2009, 09:26 PM
  5. Lamest maching question ever -- mill reach
    By juno in forum Benchtop Machines
    Last Post: 10-05-2007, 01:45 AM
