Hi!
I had an Alarm 17 on my Spindle drive board and I have sent it to repair. After I got it back the parameter from the NVRAM were set to the standard value.
Now if I put in M3 S2000 the Spindle turns with 5 RPM.
Fanuc support told me that this is because the wrong parameter in the NVRAM.
So now I am searching someone who has the same machine or spindle and can give me the parameters.
Here are the specifications:
Spindle Motor: Model 18P Type A06B-0728-B194#3000
Drive Unit A06B-6959-C212
Drive Type: A06B-6059-H212
PCB: A20B-1003-0010/14B
The parameters can be read in the following way:
1. With power on Press all 4 buttons (mode,up,down,data set) simultaneously until the display shows FFFFF
2. Press MODE button and use up and down buttons to go to differt parameter locations
3. Release the Buttons and the value of the parameter is shown.
4. Repeat step 2 and 3 for all parameter...
PLEASE can someone help me and write down the parameter for me or does someone have a original parameter list from cincinnati?
THANK YOU
