could use a little insight on this. I pulled to servo motor from the live tooling and found that the shaft is bent. assuming that this is causing some noise in the feedback and that is where this alarm is coming from. happening quite often. just wanted to see if anyone else has seen this fault and what other possibilities there could be before I drop the money on a new servo.
TIA
