585,712 active members*
4,126 visitors online*
IndustryArena Forum > CAM Software > Autodesk CAM > Autodesk Post Processors > Autodesk HSM post-procesor DOOSAN PUMA V550
    Dec 2018
    Hello, I'm starting to create programs in the HSM for DOOSAN PUMA V550 Fanuc 32i- MODEL A without the Y axis. I'm using the postprocessor to generate the program: https://cam.autodesk.com/posts/downl...l-turn%20fanuc
    All required so far, only when I am milling in the "X-" axis does not rotate the C axis by 180 degrees but program want to milling in "X-" where the machine comes to the limit switch.
    I want to ask whether the post-processor can be edited so that values marked with red have positive "X+" and C would be automatically added to 180 degrees.
    Thank you for your comments and I wish you a nice day.
    Sorry for my english.
    For example:
    O1001
    G21
    M24
    N1(2D KAPSA1)
    G28 U0.
    G28 W0.
    M90
    G54
    G98 G18 M35
    G0 G28 H0.
    T0101
    M8
    G97 S3500 M3 P12
    G0 Z14.
    X112.994 Y0. C179.147
    C0.
    G12.1
    G1 X-112.982 C0.841 F1500.
    Z9.
    Z6.5 F156.
    Z-1. F30.
    X-113.039 C0.823 Z-1.259
    X-113.197 C0.762 Z-1.5
    X-113.314 C0.708 Z-1.604
    X-113.422 C0.65 Z-1.707
    X-113.548 C0.568 Z-1.787
    X-113.656 C0.479 Z-1.866
    X-113.759 C0.37 Z-1.916
    X-113.835 C0.256 Z-1.966
    X-113.872 C0.172 Z-1.977
    X-113.894 C0.086 Z-1.989
    X-113.901 C0. Z-2.
    C-1.454 F156.
    G3 X-113.263 C-1.773 I0.319 J0.
    G1 X-107.449
    G3 X-106.81 C-1.454 I0. J0.319
    G1 C1.454
    G3 X-107.449 C1.773 I-0.319 J0.
    G1 X-113.271
    G3 X-113.901 C1.457 I0. J-0.315
    G1 C0.
    G2 X-119.816 C-4.633 I-5.107 J0.
    G3 X-120.684 C-9.488 I1.185 J-2.553
    X-117.447 C-10. I1.619 J2.302
    G1 X-90.356
    C10.
    X-130.356
    C-10.
    X-117.447
    X-117.275 C-9.996 Z-1.989
    X-117.104 C-9.985 Z-1.977
    X-116.935 C-9.967 Z-1.966
    X-116.706 C-9.929 Z-1.916
    X-116.488 C-9.878 Z-1.866
    X-116.312 C-9.823 Z-1.787
    X-116.148 C-9.76 Z-1.707
    X-116.031 C-9.706 Z-1.604
    X-115.924 C-9.648 Z-1.5
    X-115.802 C-9.569 Z-1.259
    X-115.764 C-9.54 Z-1.
    Z9. F1500.
    X107.729 C0.841
    Z6.5 F30.
    Z-1.
    X107.673 C0.823 Z-1.259
    X107.514 C0.762 Z-1.5
    X107.397 C0.708 Z-1.604
    X107.289 C0.65 Z-1.707
    X107.163 C0.568 Z-1.787
    X107.055 C0.479 Z-1.866
    X106.952 C0.37 Z-1.916
    X106.877 C0.256 Z-1.966
    X106.84 C0.172 Z-1.977
    X106.817 C0.086 Z-1.989
    X106.81 C0. Z-2.
    C-1.454 F156.
    G3 X107.449 C-1.773 I0.319 J0.
    G1 X113.263
    G3 X113.901 C-1.454 I0. J0.319
    G1 C1.454
    G3 X113.263 C1.773 I-0.319 J0.
    G1 X107.449
    G3 X106.81 C1.454 I0. J-0.319
    G1 C0.
    G2 X100.895 C-4.633 I-5.107 J0.
    G3 X100.027 C-9.488 I1.185 J-2.553
    X103.264 C-10. I1.619 J2.302
    G1 X130.356
    C10.
    X90.356
    C-10.
    X103.264
    X103.437 C-9.996 Z-1.989
    X103.608 C-9.985 Z-1.977
    X103.776 C-9.967 Z-1.966
    X104.005 C-9.929 Z-1.916
    X104.223 C-9.878 Z-1.866
    X104.399 C-9.823 Z-1.787
    X104.563 C-9.76 Z-1.707
    X104.68 C-9.706 Z-1.604
    X104.788 C-9.648 Z-1.5
    X104.909 C-9.569 Z-1.259
    X104.947 C-9.54 Z-1.
    Z14. F1500.
    G13.1
    M5 P12
    M9
    M25
    G28 U0.
    G28 W0.
    G28 H0.
    M34
    G54 M80
    M30
    MrSolution Guest
    Re: Autodesk HSM post-procesor DOOSAN PUMA V550
    Can you post your project ? I can help wih getting proper code along with postprocessor
    Cheers
  1. Anyone else have a Doosan V550?
    By Technical Ted in forum Daewoo/Doosan
    Last Post: 05-20-2015, 04:27 AM
  2. I need parameter´s list for Puma V550
    By mantenim in forum Daewoo/Doosan
    Last Post: 01-12-2012, 05:53 PM
  3. Replies: 2
    Last Post: 10-05-2011, 12:25 AM
  4. Doosan Mechatec V550-T
    By zman300 in forum Daewoo/Doosan
    Last Post: 02-07-2011, 09:16 PM
  5. doosan v550/fanuc 18t
    By davehrdy0909 in forum Daewoo/Doosan
    Last Post: 10-09-2009, 02:16 PM
