585,948 active members*
3,931 visitors online*
IndustryArena Forum > CAM Software > ArtCam Pro > Artcam 2008 4th axis
    Sep 2010
    54
    I made 4 axes for my cnc. I run CNC with mach3 program. I tried to make the G code for the 4th axis in Artcam2008, but I do not know which postprocessor to choose? 4th axis I have X-axis oriented. G code I tried to do as instructed from the video on youtube . Artcam makes a g code and makes the simulation correct but does not enter the A axis into the file with g code.
    https://www.youtube.com/watch?v=AoRbLgOvoxc&t=169s
    Attachment 407812
    Oct 2016
    1174
    Re: Artcam 2008 4th axis
    Because you only have a postprocessor for 3 axes! Need postprocessor for 4 axes!
    Sep 2010
    54
    When creating a milling path, (Z level roughing) for 4 A axis, how to define Z Slices? If I leave Avtomatic, it begins to milling 0.5mm (the material allowance I have set is 0.5mm) above the center of the cylinder and not at the height of the cylinder.
  1. sos, relieves en artcam 2008
    By melba in forum ArtCam Pro
    Last Post: 09-02-2014, 11:49 PM
  2. Need help on artcam pro 2008 version.
    By M.Abid in forum ArtCam Pro
    Last Post: 03-21-2014, 10:37 AM
  3. artcam 2010 examples to artcam 2008
    By mishu28nmv in forum ArtCam Pro
    Last Post: 06-15-2011, 06:27 PM
  4. Artcam 2008
    By Vegabond in forum ArtCam Pro
    Last Post: 06-22-2010, 02:25 AM
