585,977 active members*
4,670 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Teach-myself - Heidenhain Manual Plus 4110
Results 1 to 6 of 6
    Apr 2006
    21
    Lightbulb Teach-myself - Heidenhain Manual Plus 4110
    Hi all!
    As in the subject - I've got an access to a new lathe with mentioned control and I'm about to start learning how to deal with this machine/control and how to start creating my own parts. Of course I have to learn how to programm etc...
    What indications could you point me for the beginning??
    I've already found some related links (link1, link2 and link3) but I'd like to get some more "practical" suggestions.
    Any reply would be much appreciated, thanks in advance
    Aug 2006
    246
    If you're new to G-code I would get familiar with the basic codes first (G1, G2, G0, G41, etc). Then concentrate on the machine/control specific codes. The best way to learn one machine is to read the manuals that came with it. Be ready though, the older Heidenhain controls were a bear to program and use.
    :cheers:
    I don't know much about anything but I know a little about everything....
    Sep 2004
    10
    Greetings Grezeniua,
    I cannot speak directly about Heidenhain's CNC programming interface, but
    your question seems to be asking more about practical suggestions to
    begin learning CNC programming. I hope I am right . . . .
    First I took a look at your Links and right away Link1 looks super cool.
    What it will allow you to do (if I reviewed correctly) is map your G code
    moves on a test plot (the pilot) before the actual machine implements
    the resulting G code. This looks like a great way to start the learning
    process.
    Now, for what I would do as a first part scenario. What is it you wish
    to make? Something simple and basic is a great choice, but it should
    be something relevant to your goals.
    Try this:
    1. Get a piece of Aluminium stock in your hands. Something close
    to desired shape. Put it right there on your desk. Make it an
    oversized piece too. Hopefully, its round too!
    2. Imagine 10 to 50 mm held by the lathe chuck or collet. Here is
    good rule of thumb -- extend your stock max of 3x stock OD beyond
    your workholding device and have .3 of OD as minimum to grip.
    I like this for my own needs (it varies of course) and others
    will have theirs. You will develop your own intel as your experience
    grows.
    3. Begin to see how you would initiate a ROUGHING sequence to
    FACE the front of the part to a desired length before a final finish
    face length.
    4. Next make a similiar ROUGHING sequence to Turn the outside OD
    to a desired dimension. I go for something like .015 over final finished
    dimension on the part OD (oops --- .05mm!).
    Now for the Roughing of the face and OD you can select a specific Tool.
    I use a lot of VNMG/A tooling and have found a CNMG/A insert is great
    as the Roughing tool.
    5. You have the basic part "Roughed" to shape. Something like .05mm
    over final finish dimension.
    6. Select a new tool to begin your FINISH op. Follow the same paths
    as applied in the Roughing steps above but all of your dimensions
    should be set to create a finished machined part that matches the
    respective print dimensions you also have conveniently placed
    near your calipers and your stock.
    Ok -- how was that? You got some metal, you have a print and you have
    some way to measure and you have the heidenhain Pilot control to
    teach you the science of part profiling the CNC way.
    Here is some other bits to begin understanding:
    1. Tool change clearance --- critical ! Start now to determine a safe
    area to make all tool changes free of your stock. This will be implemented
    with respective G code moves. I like X and Z moves in a single format.
    Like this:
    G01 X -2. ; part OD dimension times 2 (assume part OD is 1.0)
    Z 5. ; face of part = Z0. so Z goes to 5.0 in front of part face
    Now this is a safe place to index tool turret depending on your longest
    tool extension.
    2. tool offsets. Setting tool offsets according your
    part's length beyond the workholding face this is the Z value from
    a "home" position. And then an X value based on tool touching the
    stock. Here many machines will do something unique. My machine
    for example has all X moves as Radius values. Your machine may
    or may not use this discipline. Find out right away and know it.
    Get these 2 principles understood quickly and you will be on your way.
    How have I done so far? I feel I am not helping too much, but maybe
    confusing you more . . . . I hope my rambling is right for your question!
    Would like to hear how the Pilot application works out for you.
    I have developed my own ritual for programming and can you show
    you a basic layout for my own G code applications if it will help.
    And others will have their individual rituals as well. As we say in
    my workplace --- "its all good"
    enjoy the learning,
    scott
    Jul 2005
    12177
    Don't get discouraged if it all seems very confusing; it takes some time for things to soak into your brain. I had a few decades of manual experience but I bought a Haas lathe without ever having done any programming. It took me six weeks puzzling through the manual and pushing buttons on the machine before I had a successful program.
    Apr 2006
    21
    OK! Thanks to all of you! I've just took part in a 2-days training for setting-up the machine and finally defining tools & programming...
    I think I'm able to build my own programm and to create a desired component
    Now I have more questions: could you advice me some PC programm to manage my NC programs/store them externally? Is there any free small application compatible with Heidenhain Manual Plus 4110? If so, then please send it to [email protected].
    I have a network connector, serial (RS232) and USB? Do the cables need to be "crossed"? I suppose yes, but wanna be sure!
    How to configure the communication from Win2k system? If anyone has an experience exclusively in that control unit, please share your indications!
    Thanks in advance, Greg
    Jun 2008
    23
    Need help in deckel maho cnc machine
    Dear Sir,
    How r u?
    I have one CNC machine. Complete detail with model is given below:
    Machine Model: 64V Linear.
    Machine Maker: Deckel Maho
    Machine controller: Heidenhein iTNC530
    In this machine I m facing one problem of I leak Led at power supply UV 123. That problem solved and now I have new alarm on the machine.
    When I ON the machine and after complete CNC system booting. Machine gave “relay ext. dc voltage missing”.
    When I ON the drives the all drives gave READY green LED. But after few seconds all drives off and machine at LCD screen gave alarm of
    C3B0 Motor X does not rotate or some times it’s gave C380 Motor X not controllable.
    Please give me the technical guidance to resolve my problem. Drive model is UM113.
    I have no any manual and electrical drawing.
    Hope you give me positive response.
    My email id is [email protected]
  1. Help with Heidenhain 4110 Control
    By Eggo von Eggo in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-26-2007, 10:47 PM
  2. Need post for hied 4110 lathe
    By mick173 in forum Mach Software (ArtSoft software)
    Last Post: 02-23-2007, 05:03 PM
  3. Teach Yourself G-Code
    By Switcher in forum G-Code Programing
    Last Post: 11-20-2005, 06:28 PM
  4. Proper Use of TEACH?
    By squarewave in forum CamSoft Products
    Last Post: 06-25-2005, 01:30 AM
  5. Did you know you can Teach Onecnc?
    By HuFlungDung in forum OneCNC
    Last Post: 05-31-2003, 02:08 AM
