585,974 active members*
4,338 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > HAAS TM1, (2004, but new to me) spindle maxes out at 750 rpm.
Results 1 to 7 of 7
    Feb 2008
    13
    Hello; Anyone know what im missing here? I just powered up the newest addition to my shop, a 2004 TM1 mill and the spindle will not go over 750 rpm in manual mode.
    HAAS controls are new to me, I cant find anything in the manual about this. Do I need to initiate a gear change or does that happen automatically?
    Also, this mill has a safety switch, like a "deadman switch" that the manual says has to be held down anytime the machine is in auto mode. Is this some kind of joke (lol)? Seriously, I surely dont have to stand there holding a switch for a half hour to run a half hour program, do I?
    On a more general note, is there someone out there with experience on a similar vintage TM1 that I could PM with some questions? I would very much appreciate it.
    Don
    Feb 2008
    13
    Re: HAAS TM1, (2004, but new to me) spindle maxes out at 750 rpm.
    Ok, I will update my own post;It turns out the safety switch is responsible for limiting the rpms. I discovered this by accident. The manual clearly says letting go of the switch stops the spindle, but for some reason not on this one.
    Also, i stumbled across an old thread discussing these safety switches and various strategies for dealing with this ridiculously limiting device. I suppose I understand the safety/ liability issue with an unguarded machine, but this switch debacle is not a realistic solution!!
    Thanks all.
    Apr 2018
    6
    Don,
    we own a tm1 from 2006.
    we upgraded it with a self made enclosure and also speeded up the spindle speed to 6000rpm.
    please contact me in case of any questions.
    please see picture attached.
    Apr 2018
    6
    Don,
    Apr 2018
    6
    Attached Thumbnails Attached Thumbnails IMG_9069.jpg   IMG_9070.jpg   IMG_9071.jpg   IMG_9072.jpg
    Nov 2012
    145
    Have you tried the key on the side of the control panel?
    Mar 2019
    About the "deadman" switch there are some steps you most follw to "skip" this:
    1. After you start the machine, you have to send it to home by hit the "power up" button.
    2. After the three axes had arrived to zero, you have to hit the "Settings" button
    3. Introduce the number"51" using the keyboard
    4. Hit the "down" arrow. This will take you to the settings display, with the setting 51 selected.
    5. Hit the "left" arroy. With this, te value of the setting 51 becomes to "on"
    6. Hit the "enter" button.
    7. The "deadman" switch has become overrided.
    I hope this would be useful for you.
    Best Wishes
  1. 2004 Haas Super Mini Mill Problems
    By Josh00 in forum Haas Mills
    Last Post: 02-23-2018, 10:03 AM
  2. HAAS SUPER MINI MILL 2004 - SINGLE PHASE HELP
    By CCF_CUSTOMS in forum Canadian Club House
    Last Post: 02-14-2018, 10:47 PM
  3. 2004 SL30 Spindle won't turn
    By CaptainKev in forum Haas Lathes
    Last Post: 07-13-2012, 05:28 PM
  4. Drip feeding to a 2004 HAAS VF-2.
    By dylskee in forum Haas Mills
    Last Post: 07-19-2011, 04:27 PM
