585,763 active members*
4,191 visitors online*
    Dec 2018
    The problem with threading Mach3 Turn on CNC turning
    Hello!
    The problem with Mach3 Turn - does not display the actual spindle speed (S True) of the turning CNC. The signal from the sensor on the spindle comes to the board, and even Mach3 sees it (the index blinks on the diagnostics tab in the Mach3 lathe), but the speed does not show as if there is no sensor. I tried to put different sensors - hall, reed switch, induction - the result is one.
    Recorded video - the essence of the problem is revealed - see: https://www.youtube.com/watch?v=z2CN...ature=youtu.be
    The purpose of the idea is to cut the threads on a lathe from Mach3 Turn.
    Spindle rotation speed: 200-2000 rpm. Real speed does not show either the minimum speed or the maximum.
    The machine is homemade.
    I also attach a file with settings: https://drive.google.com/open?id=1_x...N1rytmD69GXwm-
    And screenshots of settings.
    Thanks in advance! Glad any help!
    Apr 2014
    215
    Why have you enabled encoder 1 AND index on the same port + pin?
    Apr 2014
    215
    Check out page 43 here
    https://www.google.com/url?sa=t&source=web&rct=j&url=http://www.machsupport.com/wp-content/uploads/2013/02/Mach3_Threading.pdf&ved=2ahUKEwjR19Og2KffAhXKyqQKH dzgDNgQFjAAegQIARAB&usg=AOvVaw3rf1Z4N_9dSDgWwaTq10 eJ&cshid=1545078196994
    Jun 2010
    4256
    Re: The problem with threading Mach3 Turn on CNC turning
    It does - provided you have allocated the pins correctly.
    Cheers
    Roger
    Aug 2019
    339
    You need to turn ON the spindle via the MDI first. Example: S500 M3 <enter>
    Then your pulse will be read by MACH3.
    edit: and I've just noticed I'm replying to OP on a thread started a millennium ago :/ oops
  1. CNC Turn threading problem
    By José L. in forum G-Code Programing
    Last Post: 11-28-2014, 01:03 AM
  2. need help bobcad lathe mach3 turn threading
    By hanover owing in forum BobCad-Cam
    Last Post: 10-16-2012, 11:55 PM
  3. CNC Lathe : OD threading turning = thread entry burr problem
    By ghettosled in forum MetalWork Discussion
    Last Post: 10-02-2009, 07:26 PM
  4. Threading problem with Mach 3 Turn
    By meincer in forum MetalWork Discussion
    Last Post: 12-18-2008, 03:04 AM
  5. Oval turning using formulae in Mach3 Turn
    By rajiv.tctech in forum Mach Software (ArtSoft software)
    Last Post: 03-12-2008, 07:26 AM
